I have a 2008 GEM E4. I just replaced the motor with the D&D blue motor. There is what appears to be a bolt about 3 centimeters wide with a pin in the center of it, that slides in and out, in the transmission housing right below the motor. It is leaking what appears to be clear transmission fluid. It looks like it is some kind of pressure release valve.
Does anyone know what would cause this and should i be worried? Thanks.
The below company makes a GEM motor replacement that is of higher quality than the stock motor. Ride for Fun uses this motor as well. You can have the company ship direct but they do not support any programming or other questions. It’s cheaper direct but there is no support. You can pay more from others that will help reprogram for higher performance. You can google a video on how to swap out the motor with your original. Go to their site or ride 4 fun and you can see the blue casing which is why it’s called the blue motor. Thanks.
Does your magic magnet act as the magnet and adjust the speedo, which increases speed, or does it just correct the magnet effect on the speedo to show the correct speed and and require the purchase of the magnet as well? Thx
The MM is a scaler. Passing a % of pulses to speedometer.
Much as a speed magnet passes 50%.
By setting MM to 40/25 it reads 0-40mph when speedometer is in kph.
It will then “allow” speed of 40mph.
Only works with standard magnet.
Also allows fine tuning up or down to correct for gears and tire size.
TimFitz
January 25
I bought your magic magnet and it did not come with any instructions. Can you please let me know what the default setting is at? If I need to change it, what is the sequence? I see 3 setting pin switch inside the housing. How to I set them and do I just need to switch my controller to KPH? Any other controller settings that need adjustment? Thanks.
No, it works with any combination when used on stock motor and controller.
Speedometer setting has no affect on operation.
Make sure speedometer is reading correctly without the MM in place.
