Whether you are a hardened veteran of golf course, Or an enthusiastic amateur, Almost have the same deployment of technology and information of club, and whether you are male or female players, when choose golf clubs which accompanied with you almost timse, you should tell yourself just choose the right one.
The first step
Handle the important, when determining the choice of club is the first consideration. Grip of a thickness suitable for play in the play in the swing is a critical step. Too small to handle, the swing will make your hands larger room for maneuver; too thick handle it, would limit the action with both hands. What is the proper grip? That the grip, the grip should allow the left middle finger and ring finger just touch. If your middle finger and ring finger can not touch his thumb, the lever means too thick; the other hand, two fingers, thumb knocked over too much, it means that bar is too small.
The second step
Shaft: When in the choice of club, taking fully into account their height, size and strength. Body type if they are high, then the selection of the best club side when the shaft length should pay attention to a number of more rigid, bearing in mind the flexibility of the shaft. Another point that needs attention is the sound of swing. If rustled, and is the culmination of the swing, the rod was bending the branches of the same picture, then it must be very hard and some of the shaft; if the swing did not hear any sound, in the swing vertex straight shaft, such as when the foot, then the general hardness of the shaft only; if somewhere in between, you can choose a moderate hardness of the shaft.
The third step
Face angle of legs the ball: the ball can determine the angle of flight path. If you hit the curve ball is right, then the face angle of legs with the ball smaller clubs, to avoid a similar situation will occur. To pay attention to a basic general rule: the closer the ball away from the stand, you need to angle smaller clubs; the contrary, the club will larger angle.
The fourth step
Head: head sub-standard, medium-and large few. For starters, the proposed use of large head. Large tolerance for a larger clubhead, it is easy to play beginners build confidence.
The fifth step
Irons: just join for the novice,taylormade r11 irons, the large metal wood club head should be something more popular, because the greater the play more face less prone to error, it is best to buy back and oversized hollow Golf irons. The high-level players prefer to choose the most suited to their swing irons. Thick, hard forged irons are more suitable for those who can accurately hit the ball players face,mizuno mp 64 irons, and concave back irons, the ball club face for those who like big players.
good artculo
i like ittttt ;d
