Saw this one, and want one! Any suggestions where to buy?
I’ve got the old wobbly ‘links back’ and it just doesn’t work right. Bags twist, angle and height could be better. If this is home made, somebody did an excellent job. Thanks for your sleuthing.
              First solution is to possibly fix what you have. Look into why your linksback is wobbly.
If you look at the pegs at the bottom where it goes into the pockets at the bottom, are the rubber feet still there? They should be tight fitting (not worn out or missing)
You might also consider running a thick foam pad between the links back frame and the back wall of the cab.
-or -
TRy running a couple ratchet straps and secure the carrier to the frame a bit more than it is now.
              Thanks, first reply as always! The key problem is that the links back seems to be designed by no one who ever used it to play golf. The layout angle is canted rather than vertical, making clubs drag on the sides of the bag when going in and out. It works best when vertical. The height is considerably too tall, meaning that a 7’ tall golfer has no trouble lifting out a club to clear the bag, my wife . . . not so much. Again; what impressed me was the ergonomics of the cart club carrier in the photo. Having ample baskets available to toss in the ‘head covers’ is a plus (not Burkas for Clubs, the kind that has the club number and brand!).
I’ve gone through my carrier and it works as well as it can, but not as well as a carrier should.
Plus; I want to say kudos to whomever designed that one in the photo.
R.
