@grantwest would you still have the drawing of the 8pin → 12pin instrument cluster adapter for a T1 to T2 upgrade?
I’ve learned the long way(finding a problem, eliminating things, looking at drawings, etc ) and then found this thread after @AssyRequired pointed it out. Now that I have the Motor Thermal Switch hotwired, I’m looking to get the display functional again and some of the drawings and links in this old thread don’t work or show. Thanks.
8 pin “Y” connector for display and programming(handheld only):
01-02-03-04
05-06-07-08
1(grn) Clock(Out)
2(wht) DATA(Out)
3(red) ENABLE(Out)
4(shld) Negative
5(blk) 5+ SUPPLY
6 STORE(In) (Handset)
7 FUNCTION
8 VALUE
12 pin “Y” connector for display and programming:
01-02-03-04-05-06
07-08-09-10-11-12
1 Clock(Out)
2 DATA(Out)
3 ENABLE(Out)
4 Negative
5 5+ SUPPLY
7 Im OUTPUT
8 VALUE
9 FUNCTION
10 N/A
11 SERIAL Receive(Rx) NOTE: same as P23-22 (Rx)
12 SERIAL Transmit(Tx) NOTE: same as P23-23 (Tx)
