Stuck brakes on e825
2003 e825
I feel like my brakes are sticking. (it may just be the regen of the engine) Is there away to dis engage the motor so I can free spin my tires?
It should only be a few bolts holding the motor to the transmission. You’d want to disconnect the wires from the motor as well to remove the motor from the vehicle.
Jack up the car. with both wheels off the ground wheels will turn easy.
The rear brakes have stuck on my e825 and it has been the parking brake lever rusted to the backing plate. After getting the drum off a little wd 40 and I was good to go. I hope this helps. Bob
