Hi. I am a regular over at ecomodder but for this project I figure I better go to the forum that deals with what I am building.
I recently built a Metro XFi Convertible with a custom frame and pretty much totally custom built everything. It is getting great mileage as it is but I always want better. About the only thing that will give it to me is to add electric drive. So I have been reading and thinking about it and what I want out of it is pretty simple hopefully. I am keeping the gas engine and going to attach a sprocket to the drivers side CV axle shaft. I will mount the motor somewhere under the hood. If I can get it to drive for 5 minutes at up to 35mph I will consider it a success. I would like more than that if possible but that is my baseline. There is pretty much no limit to what can be modified on the car so even if I need to move the firewall to make room that is only a minor job as it is no longer structural.
So far my plans are an Etek PMAC motor and a Kelly Controllers KBL72301 It has a 300A Max, 150A continuous current rating and can handle 72V. I figure 6 AGM-31 batteries seems to be good batteries for the price. All of these items are still up for debate so I am not stuck with using anything right now and am willing to change it all.
So far the only thing I have done is to print out the motor mounting bracket to proper size and use that to measure and see where everything fits.
An Etek will fit in there with plenty of room with only moving a few things around and moving the radiator a few inches to the left. I think I can go up to maybe a 36 tooth sprocket on the axle without clearance problems. I could go bigger I would just have to cut and move a few frame parts if that turns out to be a problem.
Anyone got any advice or recommendations before I start throwing money at this project?
