[SIZE=2]Image courtesy of divaco.com
Motor / Performance[/SIZE]
[ul]
[li]Type: AC electric motor[/li][li]Power in standard conditions: 8 kW / 48 V[/li][li]Max. power: 14 kW[/li][li]Maximum speed: 44 km/h[/li][li]Approved towing capacity: 250 - 275 kg (E)[/li][li]Maximum towing capacity: 2.000 kg[/li][li]Controller type: CURTIS (385\u2006A max output power)[/li][li]Setting vehicle’s performances: 2 settings controlled from dashboard (ECO and SPORT)[/li][/ul]
Battery pack
[ul]
[li]Type of batteries: 8.7 kWh LA[/li][li]Number of batteries: 8.7 kWh: 8x6V[/li][li]Range with battery completely charged: 8.7 kWh: 70 km[/li][li]Battery-charger onboard the vehicle: Yes, with on-board state of charge led indicator[/li][li]Estimated battery charge time: 8.7 kWh: 8 hrs[/li][li]Type of battery-charger: High frequency battery charger with active PFC and (only versions 9 kWh and 18 kWh) with temperature sensor on batteries[/li][li]Quick-change battery system: No[/li][/ul]
Transmission
[ul]
[li]Type: Electronic speed variation[/li][li]Driving: Rear[/li][li]Maximum negotiable slope: 35% (E)/30% (ED)[/li][li]Rear differential unit: Semi-floating[/li][/ul]
Brakes
[ul]
[li]Front: hydraulic discs[/li][li]Rear: hydraulic drums with mechanical servo brake[/li][li]Parking brake: Yes[/li][li]Regenerative brake: Yes[/li][/ul]
Suspension
[ul]
[li]Front: MacPherson-type with independent wheels[/li][li]Rear: With De-Dion bridge + stabilising bar[/li][/ul]
Online reviews: TBA
