[SIZE=2]Image courtesy of alkè.com
Motor / Performance[/SIZE]
[ul]
[li]Type: AC electric motor
[/li][li]Power in standard conditions: 8 kW / 48 V
[/li][li]Max. power: 14 kW
[/li][li]Maximum speed: 35 km/h
[/li][li]Approved towing capacity: 250 - 275 kg (E)
[/li][li]Maximum towing capacity: 3.000 kg
[/li][li]Controller type: CURTIS (385\u2006A max output power)
[/li][li]Setting vehicle’s performances: 2 settings controlled from dashboard (ECO and SPORT)
[/li][/ul]
Battery pack
[ul]
[li]Type of batteries: [14.4 kWh LA] std [18 kWh PL] opt
[/li][li]Number of batteries: [14.4 kWh: 24x2V] [18 kWh 8x12v]
[/li][li]Range with battery completely charged: [14.4 kWh: 100 km[E] 95 km[ED] [18 kWh: 130 km[E] 125 km [ED]
[/li][li]Battery-charger onboard the vehicle: Yes, with on-board state of charge led indicator
[/li][li]Estimated battery charge time: [14.4 kWh: 8 hrs] [18 kWh: 12 hrs]
[/li][li]Type of battery-charger: High frequency battery charger with active PFC and (only versions 9 kWh and 18 kWh) with temperature sensor on batteries
[/li][li]Quick-change battery system: Yes
[/li][/ul]
Transmission
[ul]
[li]Type: Electronic speed variation
[/li][li]Driving: Rear
[/li][li]Maximum negotiable slope: 27% (E)/25% (ED)
[/li][li]Rear differential unit: Semi-floating with tapered bearings
[/li][/ul]
Brakes
[ul]
[li]Front: hydraulic discs
[/li][li]Rear: hydraulic drums with mechanical servo brake
[/li][li]Parking brake: Yes
[/li][li]Regenerative brake: Yes
[/li][/ul]
Suspension
[ul]
[li]Front: MacPherson-type with independent wheels
[/li][li]Rear: With De-Dion bridge + stabilising bar
[/li][/ul]
Online reviews: TBA
