2010 Zone Electric 4 Seater Cart FOR SALE
Has approx 1 mile on cart.
I bought it to take to the lake house and had a change of plans.
It has set in my garage since I received it in June and I drove it around the neighborhood a couple of times. I would love to keep it but I have a new addition to the family on the way and could use the money more than the cart!
The cart is a 48 volt white 4 seater with an extended top.
Asking $5800.00 OBO
Located in Baytown, TX (approx 30 miles East of Houston)
PayPal payment is an option.
Please call or e-mail me @ tkm832@gmail.com Ph# 281-831-1258
Specs:
Voltage: 48V
Battery: High Capacity US Batteries 48V @ 283Ah = 13.586 kilowatt hours
Motor: SepEx Motor 4KW 5.5hp
Controller: Curtis Controller Model 1268
NEV-48 EX
Passenger Capacity: 4
Range: 50
Max. speed: 25mph
Minimum turning radius: 11ft 6in
Max. climbing ability (loaded): 25%
Max. movement after brake: ≤13ft 2in
Overall dimensions: 9ft 6in(length)X 3ft 6in(width) X 6ft 6in(height)
Max. loading weight: 780 lbs.
Net weight: 1,540 lbs.
Standard Features:
Body: Steel framework + Fiberglass
Roof: Fiberglass
Windshield: DOT Approved Windshield
Seat Belt: DOT Approved Type 2 Seat Belt
Seats: Rebound seat + artificial leather with armrest
Dashboard: Instruments forward/reverse switch, battery capacity indicator, ignition key
Beverage holders: 4 cup drink holders
Lighting System and Horn: DC-DC converter (converting from 48V to 12V), horn
Side Trim: stainless steel
Paper Holder: on steering wheel
Towing Bracket: on front of vehicle
Steering System: Single-stage rack and pinion steering system, automatic rocker compensating function
Brake System: Mechanical brake
Accelerator: Stepless speed change
Suspension System: Front and rear plate spring + vibration absorber
Driving Mode: Rear axle two stage deceleration, regenerative braking
Rear Axle: Gear ratio10.25:1
Wheel & Tire: 10x7 Aluminum wheel & 205/50-10 4PR
Reversing Alarm: Standard
