Do you folks that have GEM’s longer than I have, do you see any problems with using these tires? Do you have any recommendations for a different dealer?
Have had four GEMs at work over ten years. We have several eL trucks and use Carlisle USA Trail in the 5.3X12 size. The narrower appearance looks odd at first, but we have been using them now for years. The narrower tire actually makes steering the older GEMs easier, especially with a load. The Carlisle have a two ply sidewall, were the imported 12" tires are only one ply. The Carlisle tread comes in either four ply or six ply, which handle heavy loads well. We use the four ply # CL519077 . These tires really do last.
