Hi, very new here. I inherited my parents 2001 gem cart and all has been pretty good until recently. Over the past month, when I plug in the cart to charge, the extension cord got a bit warm or maybe even hot. Yesterday, I was charging it and it stopped charging quickly and I noticed that the extension cord plug had melted a bit and one of the three prongs on the cart was very loose (almost to the point where if I tried I could remove it like a loose tooth :)). I have not charged it since and thinking I need to replace the assembly on the cart with the three prongs. Any suggestions or experience with this?
Might not be a bad idea to consider replacing the cable going from the socket into the charger too. It’s a heavy duty IEC “computer power cord” - just cut the male NEMA 5-15 (“Edison”) end off and strip it back to screw the wires into the terminals on the MARINCO plug.
