Can someone please post a pic of the wiring connector for the headlights/blinker/horn connector under the hood of a E825? I need to see where the wires go into/from the four pin. Thanks.
Thank you! Is your horn wire cut?
No, the horn is the solid orange wire. Not sure what the yellow/green is for.
So that yellow/green isn’t connected to anything? I now have four wires (Y/G is one of them) going into the plug and only have three available pin locations.
Why is this like doing math?
BTW - I can’t guarantee my wiring hasn’t been monkeyed with by the previous operators.
Wow, thank you for doing that! Looks like the Yellow/Green isn’t used after all.I got them connected without it and everything seems to be working.
Posting photos? I know you can upload your photos to a website, and click the link icon to post. Is there a way to upload directly from your files?
When you open a reply or post window, just click the upload button circled in red. If you don’t have that button, there might be a minimum post count or something required before it becomes active, I’m not really sure how the forum software / trust levels are configured.
I traced that wire and it goes to the switch on the parking brake. I have been told that it is typically always not used because the horn would sound if you had the e brake in the up position.
Interesting set up. Happy B day BTW.
