Passenger side blinker front and rear and ,brake light not working, only on passenger side. Headlight works. Turn indicator solid red
Any ideas
Joe
Joe, I just went through this. Check the ground coming out of the four pin connector under the hood.
My four pin connector was melted. I replaced it and everything worked again.
2005 up Trouble in PDC Common problem.
Mine is a 2002
Thanks I’ll look
Would that happen a just 1 side of the gem?
Thank you
would that affect only 1 side ,the passenger side
Yes. The harness for the blinkers, horn and lights all run through that connection/ground. It screwed up all off the lighting on my car, front and back.
Once there’s a bad connection/short the entire system gets wonky.
Hi Rodney,
I hope you are well, I recently saw your profile, and I have interest in buy from you the frame adapter to make my GEM E825 2002 to 4 seats, I already have an EZGO flip seat, brand new. Thank you
Sorry I dont do those anymore.
In a message dated 5/10/2020 4:56:11 PM Eastern Standard Time, electricforum@discoursemail.com writes:
