Hello All,
I’m After a little advice please. I’m from the UK and looking to convert a 1995 Skoda Favorit to electric power. Those of you in the US won’t be familiar with this car, but think of a mk2 golf/rabbit and your not far off.
I chose the car as it has a low starting weight of only 895kgs and no mod cons such as power steering/windows/airbags etc, and because I got a 19K miles from new one in mint condition for almost nothing!
Anyway, this is what I need it to do for the project to be feasible:
- Top speed of near to 80mph
- Constant cruising ability at 60mph minimum, (ideally 70mph)
- Minimum range of around 100miles (at said 60mph)
So this is what I’m thinking so far, an AC system using 144v from 12 approx.75ah lead acid gel type, heavy duty deep discharge batteries, like Exide Maxxima 900DC or Optima Yellow Tops or similar.
I reckon I should get 4 upfront with the motor and control gear, other 8 either under the rear seat and or modified spare wheel area, I’m hoping that allowing for the new kit weight, less the removed engine and component weight, to end up at no more than around 1200kgs.
So what do you all think, can I do this, or am I being far too optimistic on range & speed? My budget is quite flexible, can probably run to around 12K to 13K dollars if need be.
My only concern is that electric cars are here in UK already, commercially built, but they are all very small (and frankly hideously ugly!) and only seem to have a range of about 40 miles and a top speed of 40mph, so how come the professionals can only get this limited ability?:eek:
Any ideas on motor/controller/charger/DC to DC charger/ brake vacuum/guages etc. appreciated also, will be keeping the standard 5 speed manual tranny and clutch and getting custom adapter plate/mounting made up.
Thats all assuming you don’t all tell me I’ll top out at 30 mile range!
Regards
Paul
