New tire & rim thread
Got the info on offset for these.
They are 3+4 which should work in my favor. Correct?
Should I forget about trying to fit wide tires like this?
Grant,
Check out first picture in post #1.
The ones we talked about.
The big thing to keep in mind is diameter. With 12.44 you can pull a larger diameter than you can with a 10.35 or 8.9 If you don’t have enhanced brakes stick with the stock wheel diameter. Bigger diameter tires affect acceleration and braking in a negative way
Are the wide ones doable? 23"D
The used ones are narrow low profile 23.4"D
I can always let you help me lift a couple inches.
[quote=Inwo;27909]Got the info on offset for these.
Should I forget about trying to fit wide tires like this?[/quote]
yes these will work
