I spent the morning installing a 12V LED tape light kit around the roof line inside my GEM. The outcome is awesome. This was a very simple project.
I used 1-16 foot white only dimmable LED Tape light kit. The kits utilizes a remote on and off switch that also has a dimmer, see the picture of the remote.
I needed;
- a set of wire strippers
- a pair of wire cutters
- 3 zip ties
- Some blue masking tape
Unfortunately all the pictures I took during the install did not come out so I only have the finished product to show.
I hooked up the lights to test them off a single battery.
Then using the blue tape to hold the LED tape lights in the route I laid out to ensure I had enough.
Then I wired the remote sensor directly to one of my batteries (I will move this to the fuse block soon).
I tested the lights once more where I had them to make sure they looked good
I cleaned the area well with soap and water so the tape on the back of the lights would stick.
I then peeled the paper off the LED Tape lights and pressed them in place.
I had to go back and really make sure that all the areas between the lights were firmly secured.
I used zip ties to attach the remote activator and wires the the battery securing bar temporarily until I can run everything back to the fuse box.
I took a picture of the kit I used. I did not use the 110v power converter supply or the additional connectors provided.
This is a fully remote, dimmable LED system that sells for about $30 on Amazon. I will be purchasing 3 more RBGWW (red-blue-green-warm white)remote kits for under the dash and under the car.
This took about 1.5 hours.
I will post pictures of what it looks like at night, tonight.
