I am looking for a way to have a light such as a dome light in my car if anyone knows of a brand / method any help is greatly appreceaited.
Check out ebay for battery operated led lights with sticky back
Ok thanks for the suggestion. I don’t know if that would work because when I custom built it I put in a felt roof
Use Velcro tape to secure
I purchased a Sylvania 6 inch LED Light Bar Model #72247 from Lowes/Home Depot it is listed as an under the counter however at 6 inches it is perfect for the roof of my GEM above the dash. It comes with a magnetic base which has a double stick tape and is perfect as you can remove the Light stick simply via the magnetic holder to look for dropped stuff in the GEM, AND it turns itself off after 15 minutes if you leave it on. $13.98
@cwj3620 thanks for the idea and I’ll try that. Have you had any issues of hitting a pothole or a speed bump and having it come off since its magnetic?
No issues what-so-ever, it has been “installed” for 4 years and 15k miles. in-fact the batteries are still original! a great deal for $14 bucks
