I am trying to determine if I need new batteries or my charger is not working properly. My batteries Gem Gel batteries are now about 8 years old. My charger will not kick on and I often get a red blinking light.
I also show a charge rate of about 50% on my dash indicator. So I thought I would charge all the batteries up separate. Then see what charge rate I was showing. Is there a way to charge these as a pack? all six 12 volt still tied together? or do you suggest I do all batteries separate?
The charger will not turn on if the pack voltage is too low. If your batteries will accept a charge, you can charge them individually with a 12V charger to bring the voltage up to a point where the 72v charger will work.
As previously mentioned, 8 year old batteries are not at all likely to be any good.
2 years for good performance. Up to 5 years max. In my case, I have always had such deterioration that I replaced by year 3. And that data is over the life of several EV cart types and one commercial European EV (the CityEl). Last time I went with lithiums and have never been happier. Lithiums are now as cheap as staying with lead acid or gel.
