Need to install brake shoes on 2000 gem e 825
need help soon. thanks
cant get the shoes over the pivot
stud
Put the shoes in a vice and bump the adjusters toward the inside. The adjuster is the part that goes over the pivot pin. You can notch out a relief on the hub 3/8 by 2 1/2 between the lug bolts. Later models had these relieved areas on all 4 sides of the hub.
did that it worked…thanks
