For my 2008 ES. Does anyone have a used one for sale?
Thanks,
Dan
Thanks,
Dan
I adapt a new Saturn throttle to work electrically on a Gem. Or have a replacement switch if only the switch is bad.
Bolts in same as oem if you put your ? pedal on it.
You can diy if you like and get the switch from me.
Let me know if you are still looking, I will be home next week to check,
I have David‘s throttle tester as well as 2 new throttles that will work if you are handy with tools simply cut and bolt on the new throttle pedal and plug and play with the new replacement.
I’ll wait to hear from Dave whether to send it to you
