Can someone give me the measurements of the front battery tray on an early Gem . The one that holds the 2 batteries . I’m designing a new lithium setup and wanting to see if it will fit entirely upfront .
Lithium Gods
Lithium Gods
The wells are each 7" front to back, and 16" wide, but there is a raised ridge at one side that reduces the flat bottom area to about 15" wide. The ridge is about 1/2"-3/4" high.
Upper tray sits 3" above the lower. Hood is 20" above the tray.
any chance of a picture ?
Sure, I can pull the batteries in a few hours or tomorrow and get a photo of the tray.
Does this help? 2000 4 seater
I happen to have the front end in pieces right now. If you need measurements, i can do it. Just tell me what you need measured. The frame or tray etc
Those picture are perfect . looks like this lithium pack may fit entirely upfront .
