2016+ Lithium battery pack for sale. This is the pack I built to do some testing with Dave’s cells. It is a 14s pack that is a drop in for a stock Gem. Built in a waterproof composite case. I should have all testing done in a few days. Estimate is 30 mile range, will be confirmed shortly. This is a great pack ready to go. $1900. This pack weighs less than one lead battery.
That’s pretty dam cool a drop in lithium pack for 2016 Gem for under 2k. Gem wanted 12k for the Lithium park they offered
I’m kinda liking the “pelican box” look.
Any issues with BTooth range?
Did the 15th battery not work out?
The 15th cell worked fine but requires tweaking of the charger. On a stock setting, 14s is the better way to go. I removed the 15th so it would be a direct drop in for someone.
Could you tell me a little more about the necessary adjustments, Michael? I’m debating between a 2p14s and a 2p15s in my eM1400.
IF your cart came with agm or gel batteries the charger can be spoofed to increase voltage. 2018 gem is 56v stock but can be upped to at least 60v. If it is set for flooded it may have to be changed to agm first.
Thanks. Yes, mine (2015 eM1400LSV) came with 8 AGMs.
So you didn’t load a lithium charge profile?
Now that you mention it, I realize I’ve never hooked up a programmer to the charger to see what is on it.
@JarJarJava - From what I’ve been reading, the charge cycle on the later Gems are controlled/dependent/highly monitored by the ECM. LG has not found a work around.
Is your eM1400 set up the same way?
The em1400 is a completely different animal than the traditional gems, they are closer to the Polaris ranger EV. They only have the sevcon controller, sevcon dc converter and delta q charger. They also have a completely different dash and speedometer. They are also rear wheel drive.
…and I believe both 14 & 15 came with unlocked controllers. According to Dave, my 15 is unlocked, as is his '14. I don’t have the Sevcon PC software yet though.
We found away around for the charger.
Finish testing should be done next week.
See if it’s on #28.
In your case just program it and be done.
#28 has float and means bms should be set low enough to interrupt charge cycle. Best in any case. IMO
Did you see connectors from digikey?
Also foot long snaps.
Should have some soon.
saw them, looks promising. I will test with resistors next week
Does anybody know of someone or dealer that makes a lithium drop in plug and drive battery pack for the 2018 Polaris E-2. This pack must be able to be charged by the onboard Delta”Q” model 912-4854-05 charger. Not intrested in holding my phone while I drive to monitor batterys, to me that’s not plug in charge and drive. The center charge cluster must be able to monitor the battery’s. I’m located in San bernardino co. So. Calif., please Email me at tgarcia92354@gmail.com with any info and price or a good price on replacement AGM 12 volt 120AH LEOCH Batterys (4) that are ending their life cycle………
I have a battery that works with the oem deltaq and the oem cluster but its in development and I’m not cheap ![]()
I tested one and it was great. Big improvement in performance
I have one more 12s 224ah 10kwh SDI module.
Electrically drop in. tested in E2 60 miles with correct soc function, after bmc calibration.
Not mechanically drop in. Even though it is in a bolt-in aluminum box. It needs to be removed for shipping.
