With the help and guidance of others (@Inwo, @LithiumGods, @Reddevil) here in the forum, I’ve just completed a conversion to Lithium using a 25cell pack (aka green cells).
I’ve got a 2006 e4 with a stock DeltaQ charger that cannot be reprogrammed.  So far so good and I’ve tested the recharge capabilities with success.
I bought the 25cell configuration in a 1x5 and 2 1x10 configurations. Looking back, I should have opted and/or asked for 5 of the 1x5 packs as they fit in the existing battery trays of the 2006 underneath the seat and require no modification. As a result, I had to split the 1x10 into 1x5 packs and reband the batteries, and add 2 additional battery plates. In all, not a huge deal, but took some time to cut, separate, and reband the cells together. The good news is this was my only lessons learned. The rest of the process was seamless and straight forward.
The forum here is loaded with information and folks were helpful and answered questions. While I was a bit nervous going down this path and doing the DIY approach, I’m glad I did. I saved about 1k over what two of the local golf cart and Polaris dealerships quoted me for Trojan AGM replacements, including their labor.
In all, it was about 2 hours of work to replace. It was not complicated and was pretty straight forward. I ended up following a wiring guide posted by @LithiumGods that closely mirrored my setup.
As I wired in each set of cells, I tested the voltage to ensure that with each extension, the total voltage in the packs increased accordingly (which they did). In the end, when I flipped the master power back on I was greeted with a nice green light.
So far, I’ve run about 6-7 miles today and the difference in performance is noticed instantly. There is no lag, the car accelerates instantly, and the pace and acceleration, even with 3 adults and taking an uphill climb, was noticeable and impressive. This is a huge improvement over the gel lead acids I just replaced.
In all, I would highly recommend anyone looking at replacing batteries to go this route and if I can be of any assistance on what I did ahead of time or with the conversion, let me know. It really was a kit that @Inwo sold and it all worked flawlessly. I would do this again without hesitation.
