Thanks for the information fellas. At this point I think I am going to just send my calipers off to be professionally rebuilt. Luckily I found a guy who’s been rebuilding calipers for 40 years and he is 99.9% sure he can rebuild mine as he has access to custom made seals. He rebuilds a lot of calipers for old and rare cars that don’t have robust spare parts supplies.
I just reached the point where I am tired of throwing parts at this problem that bring no solution. It’s time to call in the experts, and at around $89 per caliper for the rebuild, I’m fine with that. Sure beats the price of buying new.
I will post the results in a few weeks and provide his contact information if all is successful.
@Thunderbox – The part number I have for a Brake Caliper Assembly is 0111-02365. I don’t know what years that applies to, but I do know the factory calipers on my 2008 have no manufacturer’s mark, casting number, or any way of identifying where they came from. Good luck.
I received my calipers back from the rebuilder and he said they were perfectly fine. He suggested the reason my brakes were rubbing was because my rotors were warped. I told him they were brand new and had less than 10 miles on them, but I reluctantly put a gauge on them to check the rotor runout. Turns out he was absolutely correct.
The front passenger side rotor measured .040" out of true which is about 10 times what it should be.
For some reason the mounting posts on that hub are not perfectly even and when I tighten down the four mounting bolts, the wafer-thin rotor warps. I ended up ordering a package of ultra thin stainless steel shim washers on eBay (they shipped directly from China) and I added a few between the rotor and the low post. Problem solved.
Hello. Where I can take a controller, 60v60A or similar, for Jonway Urbee micro car ?
There are many “similar” on aliexpress, but maybe not compatible and weak, and with different plugs
I have a 2013 elxd pre 10-22-12 I’m looking for rear spindles and hubs/bearings or a complete rear end. I saw you listed bearings for 4 lugs hubs am wondering if these would fit my 13 or are they for the older models.
I’m in need of a parts source for 2018 Polaris gem E-2. I need the front disc brake pads and the rear brake shoes. Does anyone have the OEM Part number or an after market source. I was informed that Polaris may have used the Polaris ranger platform to supply parts to make the gem cart ? Any information would be helpful.
Product line is LEV
Pick your year
Pick from the models listed.
2018 only showed em1400’s and possible european GEMs - I’m not sure, you’d have to look at them and see. If you go back to 2016 you can find a bunch of US models.
Thanks for your help. Nothing listed for the 2018 polaris gem E-2 , I’ll keep looking on the web and hope someone on this site knows of a after market source such as EBC Brakes.
Much like automobiles, GEMs don’t really change that much from year to year when they are all in the same generation / style, so you will have a few years that use the same parts. It wouldn’t surprise me if the 2018 brakes are the same as those on the 2016, which IIRC, was the start of the of the last generation of the classic body 72VDC vehicles.
