Anyone wanting to do a Leaf conversion.
Picture from customer.
Yes…I just started the process. Thanks for the pic!
Where do I get that BMS from?
Thanks,
Jeffrey 8189160787 call or text; text is best.
This is a standard ssr that will break ac power to charger. Easily controlled by bms-24.
$256.50:
Hi Inwo
if use Gem standard charger and switch off charger with bms24 and relay
which charge profile are best for lithium,flooded or gel ?
thanks
How many cells?
Won’t make much difference.
oki thanks for info,think i will go for 10 Leaf cells
If this had the right connectors it would be an easier install than SSR. The charger relocation is working so far but I want to add something to prevent a run away charger. I’ll probably keep adding bandaids to my DQ til it dies because the guys that go to a different brand lose the BDI.
I has the right connections. It needs the same current limit resistor as ssr.
You can make your own by cutting the black wire in a short extension cord.
Or the black wire between charger and hood.
