Hey everyone! Found an opportunity to buy a GEM last week, so I’ve been lurking on the forum for about a week or so while considering. Decided to pull the trigger and picked up this 2008 E4 with stock 7HP motor. Thing is pretty cherry. I want to unlock its full potential. I ordered the MM from @Inwo already
Next I believe i need to replace the batteries.
The current batteries are the OEM 8G31 and haven’t been replaced for 4 or 5 years. The car is charging to full charge, but drops to limp mode after traveling a couple miles. Seems like a symptom of spent batteries? Lithium seems like the best option. I want to be able to use the car sooner than later, so maybe I should consider another set of gels before that endeavor? I also want to avoid introducing new problems before flushing out the old ones? A friend of mine can get a decent price on a set of Leoch batteries. Any advice would be appreciated.
other upgrades seem like bigger tires? lower gear ratio?
Thanks in advance.
