Hi,
I am new to the whole converting to electric theme and I need some help on ideas for setups, like what motor to use (V, kW, amps, etc.), controller, charger and other bits (including the price of the setup). I would like to use the motor out a used forklift or similar thing, because the price of a new one would properly kill the project, but if there is no used motor to fulfill my requests/goal, then a new one it will be. I will be saving op for Lithium ion cells. The vehicle will be a classic mini saloon or van (for extra space for the batteries) and the goals are:
[ul]
[li] Top speed: 130-140 kmh (80-87 mph)
[/li][li] Range: 400 km (250 miles) (hopefully while doing freeway speeds most of the time)
[/li][li] Fast charging
[/li][li] Price: as cheap as possible
[/li][/ul]
I would also like to know how many batteries the project would need. I have heard the sentence “How much, how far and how fast? There’s a saying amongst electric car builders that when it comes to range, cost and speed, you can pick any two. In other words, it’s possible to build a long-range fast car, but it’s going to cost you. Or you can build a cheap and fast car, but you’re not going to get the range you probably want.” but I would still like the car to have the very good range and the top speed. I have been thinking about removable battery trays so I can remove the excesses batteries when doing short commutes.
If this project isn’t possible then please inform me and then I will think about lowering one of the goals.
Regards,
Alexander
