2003 stock e825. how many amps does the motor draw?
reason I ask, I found a lithium battery that can put out 80amps continuous. and 180amps for 10 seconds.
the amp hours are low…only 60, but I don’t need range. I only drive it a mile at a time.
I’ve seen over 250amps on launch
Average running 75 to 140 ish depending on throttle position.
If these are the lfp cells that look like gel batteries and cost like $4k-5k a set, good luck. Much better options out there for less
At least 350 amps peak for design purposes.
I’ve seen 250+ on my 2002 when I was monitoring…
tell us more about it
Will probably trigger internal bms every time you accelerate
