I posted a few years ago on the hard door problems. After wearing out two hinges, we decided to machine a set of pins out of stainless steel and then setscrew the pins to the hinge brackets. These have work for five years now. See the link below.
I could, but would need the dimensions. These have been in for about a decade. By drilling the hinge and installing 6-32 setscrews, no clip or other hardware is needed. Once the pin is secured to the hinge bracket, the pin can no longer rotate and cause the hinge bracket to wear out.
[quote=GEMmechanic;30035]I could, but would need the dimensions. These have been in for about a decade. By drilling the hinge and installing 6-32 setscrews, no clip or other hardware is needed. Once the pin is secured to the hinge bracket, the pin can no longer rotate and cause the hinge bracket to wear out.
Daniel[/quote]
What dimensions would you need? The pin size or the hole size
