I would like to know if you can change the column on a 2002 Gem. Can it be replaced with a newer adjustable column, or modified some way to give more room for the driver.
Hello,
I have not seen or heard of any adjustable steering column for the GEM.  One suggestion would be an offset steering wheel.  A number of older Porsches used these to allow easier entry and exit from the small interior without the need for an adjustable column.  I have not checked if any aftermarket steering wheels are offset.  Another possibility would be a just a smaller steering wheel.  This would pose problems for many drivers because a smaller wheel requires more effort and the steering effort needed is already high on the GEM.  In addition, a reduction of wheel diameter of two inches will only yield one inch of additional room for the driver.
Daniel
