I was given a gem e825 long bed I think it’s a 2002. It has no batteries and I have no idea if it even runs. How can I test the motor to see if it works before investing in $400-$500 worth of batteries?
Hmmm
Borrow 6 12 volt batteries. You NEED to assume that a free cart will have problems. If you cant afford to spend a $1000/$2000+ to get it running, RUN!!!
Some of the items on an old cart can be Brakes (for sure) brake cables - batteries - tires - controller - charger - Dc/Dc converter -shock bushings cracked body panels
Ok so I went out and bought brand new batteries today. My next issue is the ignition switch is missing and wire are cut so I have no idea what color wires go to the ignition switch. I was gonna go out and get a switch from nappa auto since I saw a write up on replacing the original one with a nappa one. Anyone have a clue as to what color wires are for the ignition switch by chance?
Please keep us updated with your status. I have a '00 with no batteries and no ignition switch.
Also, what batteries did you decide to go with?
I too need to test about 5 motors…Just to make sure they perform properly.
My local motor repair facility said they were unable to test a gem motor because one end is open.
Is there a motor repair company in the US, that can test the GEM motor?
Anywhere in the us is fine with me…
I service motors including on cart testing for $100 to $150 or more depending on condition when disassembled.
That sounds fair… Please tell me what to do.
email me at rodneyadiehl@aol.com
In a message dated 1/7/2020 10:25:42 PM Eastern Standard Time, electricforum@discoursemail.com writes:
