Hey
I wanna replace my batteries to lithium
I need help picking the right one
And to know if it’s an easy swap!
What are you replacing? Sort of depends on what your E6 is currently set up for.
It has the gel factory ones I think 240 ah batteries
8 6v total of 48volts
I have a 2p12s Samsung Sdi. 224ah 10kwh. Tested 60 mile range in 2016 e2.
Will not ship ups/fedex.$1750
Installed in al case + $500
My question is simple will my car RUN if I swap my old gel for a new lithium battery ??
And use the same delta q charger and use a new lithium charger as well??
Honestly, I really think you need to stick with your old lead system.
I replaced 8x6volt AGMs with 2x51.2volt 100 ah lithium in parallel and have had no issues. The delta Q profile for the AGMs is 28 and seems to work out great for the lithiums. The car BMS expects a 60 something mile range while the batteries expect to go about 80 miles. The SOC between the car and the actual batteries are close but not exact. I don’t typically go more than 50 miles on a charge so it’s not a problem for me.
It was a simple drop in and plug and play for my 2016 E4 for under $3k.
It will gallop at amazing speeds, for it will be a member of knights that say “Li!”
