Having a issue with my gym ignition switch is turning but having problems with starting the car in other words the switch is turning but doesn’t turn on the car probably takes me about 10 times until it turns on anybody know a solution
Do you hear the relay “click” when you turn key? Possibly if not either switch is bad, or the connections on the back of switch is loose.
