I have a 2002 GEM car used primarily around the neighborhood and going golfing. My trip including golf is 8 miles over a 4 hour period. Problem is the GEM only goes 7 miles and shuts down. I have charged the batteries and let set for 12 hours then checked the specific gravity. It is all in the 1275 to 1300 range. Has anyone else had this short distance problem? All cables are clean and corrosion free. Any help appreciated. Thanks…
it seems lately people have been haivng that problem not being able to get a 100% charge, but merely a 97-99% charge. We havn’t heard back from anyone thats fixed their problem all the way, but i think New Dawn had the closest to sucess solution, he checked all the batteries and found out there was one not quite the same charge as the rest of them making the charge not as full.
Hi-
I’m a GEM owner and modifier. You have to remember -that the quality of the batteries is paramount in any electric car. Your specific gravity can be spot-on, but your batteries can be totally shot. 7 miles till dead? They are gone.
The test of any battery is - [I]does it take a charge and deliver it’s energy as per the spec of the battery[/I]. By saying that it has a 7 mile range, you by definition have bad batteries (unless your charger is shot…unlikely).
Typical GEM vehicles have a range of 28 miles until the batteries are down at 20% (the lowest you should EVER discharge them). If they have been discharged below this, the battery is probably damaged. Also, if the electrolyte has ever been let to go down under the plate’s top level, the battery is damaged. I’d bet my prize pig Elmer that you need a new set of Trojan 130AH batteries. Don’t buy cheap batteries…they just won’t work. You are asking an Olympic feat of power from these batteries. Only the best will do. The batteries like to be charged and used…and they like to be warm.
They take a charge best right after discharging them. Let them stabilize for an hour after charging before using if possible.
Good luck!
Bob - Hot Springs
Just an additional comment: the range for any EV that uses lead acid batteries is affected by the outside temperature. For example, my EV, without some way of keeping the batteries warm, would have a range of less than 6 miles when the temperature is down in the teens - even with brand new batteries.
[QUOTE=Kreblon;4746]Hi-
Good luck!
Bob - Hot Springs
[/QUOTE]
2000 gem… just bought from a widow in vegas… she had 3 batteries replaced with marine deep cycle batteries… NOT SURE why not 6… anyway, still was one bad… so i replaced the other 3 with the same… PER DEALERSHIP… had it shipped to MO, and now when i plug in it starts to charge, and then the light turns yellow and beeps… any ideas…
GEMowner, has your Zivan NG1 charger been upgraded? We have three 2002 GEMs, and all of them have been upgraded by Electric Conversions, the Zivan representative in the US. Cost is less than $150. We have had this same problem with batteries not charging fully.
jrejr2345, what charger is in your GEM? If you have the Zivan NG1, the yellow flash alarm indicates the thermal sensor is bad or disconnected. Electric conversions, the Zivan representative in the US will provide you with a resistance / temperature table for testing purposes, or they will also sell you a new sensor which plugs into the top of the charger. If you have the older Schott charger, you may want to upgrade as charging technology has improved considerably in the past decade.
Daniel
How does discharging below 20% hurt the battery? Will once hurt it or is it cumulative? Thanks Dave
Hello,
If the temperature is very low, extreme discharge will allow a flooded battery to freeze. This can destroy the battery because hydrostatic expansion will crack, distort, or short out the plates. Also, if the case is cracked by expansion, the electrolyte will leak out. Deep cycle batteries are rated by the approximate number of discharges to a given percentage. The deeper the discharge, the fewer cycles until the battery fails. A multitude of other factors will determine battery longevity.
Daniel
Thanks… I honestly DONT KNOW what cahrger i have… according to NEV biz, I need a thermal sensor as well. HOPE its not just disconnected… I have ordered one, and will repost after i install it… ANY SUGGESTIONS on that… IM NOT mech inclined, but have a good friend who is a very good REG mechanic… I hoping he can do it… You know of any videos on youtube to follow… thanks
[QUOTE=GEMmechanic;8582]GEMowner, has your Zivan NG1 charger been upgraded? We have three 2002 GEMs, and all of them have been upgraded by Electric Conversions, the Zivan representative in the US. Cost is less than $150. We have had this same problem with batteries not charging fully.
Daniel[/QUOTE]
jrejr2345,
NEV.BIZ is the GEM factory. GEM technical support can tell what charger you have based on the serial number from the chassis. In 2000, there were two chargers used in GEMs, but only the Zivan has a thermal probe. Pop the “hood” on your GEM and look around the two front batteries for a wire with a little metal can on the end. This is the thermal probe. Some tools are needed to replace this as the probe wiring also includes the charger indicator lamp on the instrument cluster.
Daniel
Thanks for help… Part should be here in a few days… HOPEFULLY this does the trick… I am ready for spring and the links… Its 18 deg here today… Accroding to them, its what i need… THanks again…
[QUOTE=GEMmechanic;8608]jrejr2345,
Daniel[/QUOTE]
where is the probe… bought a new sensor… OLD one NOT hooked up… were does probe hook up…
weres the probe connect too
The thermal probe connects to the top of the battery charger. There is only one place on the charger to connect the probe, so it can’t be done wrong. Zivan, the charger manufacturer, has great technical support through their dealer, Electric Conversions.
Daniel
thanks and please excuse the my ignormance… When we popped the hood, they OLD brass end was just laying by the battery… so we thought it was just unhooked… We didnt install the new one… we secured the old one, tight to the battery under the battery holder bracket… That seems to do the trick, as it has charged to a GREEN light… MAYBE its just LUCKY, and still wrong… is ther a place on the net i can download service manual… I see some on ebay… like $5 for a download… ANYONE downt that… GEM wants $115… thanks and sorry for the stupid questions…
everything going smooth til i plugged in last night… charger wont start to work. outlet and cord are good… any thoughts… fuse??
Do you mean a manual for the charger or a manual for the GEM itself? The charger manual is a free download at:
Zivan NG1 Battery Charger
They will also answer questions about the charger. We have four GEMs that use this Italian made Zivan NG1 charger. Overall, they have been reliable and the Zivan dealer has provided good service and support. After close to ten years of use, all four GEMs have now had their chargers serviced and upgraded. This is not expensive and fixes a programing error common to the older chargers. This also allows the charger to be loaded with the exact characteristics of your batteries.
Daniel
GEMmechanic,
I have a 2002 that I bought used last year and have the yellow flashing two tone alarm going off but my batteries are not hot, so it appears to either be the sensor or I need the upgrades on the charger. What would be your next move since I do not know if the charger has been upgraded?
Thanks for your input,
Lee
Daniel[/QUOTE]
I know the 2002 model year well as we bought several GEMs that year. We have replaced one of these sensors a few years ago. I would recommend that you call the Zivan dealer, Electric Conversions, at 916-441-4161. They have been very helpful to us in the past and will help you with troubleshooting. Most often the thermistor (that tiny tin can at the end of the wire by the battery) is out of range. They will provide you with a temperature to resistance comparison chart. If the charger has been upgraded in the past, there should be a small sticker on it which reads"micro upgraded." If not, the charger should be upgraded. Electric conversions will update the software and test various internal components.
Daniel
ok… got the first issue resolved with a RIDE FOR FUN CHARGER ($700). seemed flawless… would play 18 holes of golf another mile total to and from coarse… NO HICKUPS at all… still had above 50% cahrge when done… week ago, i got in 9, and had issues… SO checked the batteries… Had ONE that was only cranking 175. So i replaced it with the same as was in it… 675 cc amp everlast. charged right up, and thought i had it fixed. well i got in 18, and had issues on the way home… it will come and go… -15 code… i turn it off and back on and get another few 100 years… i contine to do this and cut through neighbors yard, and make it. SAME thing yeasturday… anyt thoughts… when i checked the batteries orginally, one was at 500cc, instead of 675 as well… Should i change this one too??? I mainly play golf in it, and live in NE MO, so season is getting shorter. I dont want to drop $800-$1200 in batteries in NOV. ANY ideas…
thanks
Daniel[/QUOTE]
