GEM Accelerator Pedal Assembly Needed
In stock.
Magic throttle. Bolt up aftermarket pot box as shown above.
High output performance replacement throttle. .
$250
@ScottyD @AssyRequired
Will someone help diagnose Sentry monitor throttle %…?
I can’t get it to work on the bench.
Let me see if I can rig up Sentry monitor here. I’ve been thinking it might be a handy feature to have in my bag of tricks.
Hey there… Did you have any luck finding 2010469?
Like we would know what 2010469 is.
We do know what 8675309 is though.
It’s a pedal part number as mentioned in a previous post from Oct 2018… Obviously we are expected to remember this or spend our time scrolling back ready every post to figure it out. :confused:
If it’s a 2008 type throttle, no longer available.
That’s why we make a replacement.
Ask Byron for price.
If he doesn’t have one, i can build one for you.
I have some in process. Can prep one to ship Mon if needed.
A few other things taking priority lately.
2 refurbished ready to ship
email me rodneyadiehl@aol.com
I know this is a older thread, but I’m stuck on a issue: I need to replace a drive sol p# 050g-e4634. I have a 2008 Morgan Olsen stepvan with only 50k miles. My pedal is bad. I know for sure it’s the pedal. I have a 2007 workhorse chassis with a Navistar vt275. 6 cylinder 6.0 pretty much. All suppliers have abandoned me. Im looking for any info. I’m lost and have limited electrical knowledge, but have the skills to fab anything to make a aftermarket pedal work. I noticed you mentioned the drive sol p# 050g-e4634. What’s your experience with this pedal? Have you successfully replaced it? So far I have DriveSol / Teleflex 050G-E4634 (Original OEM)
Idle APP: ~0.9%
Idle RPM: ~689
WOT APP: ~102%
Faults: None (when signal stable)
Issue: Worn first ¼ of resistive track → instability
Conclusion:
This is the only pedal family the ECM fully accepts.
Near-zero idle. Passive analog dual-track. Correct correlation.
This defines your required voltage envelope.
:cross_mark: :two: Williams 131973
Idle APP: ~7%
Idle RPM: 800–900
Fault at: ~13%
Conclusion:
Preloaded idle too high. ECM rejects immediately.
:cross_mark: :three: Williams 131507
Idle APP: ~9.1%
Idle RPM: ~1100
Fault at: ~12%
Conclusion:
Even worse preload. Incorrect scaling for VT275 ECM.
:cross_mark: :four: Williams 134030
Idle APP: 0%
Fault at: ~12%
Conclusion:
Idle scaling looked correct, but sweep ratio / channel correlation incorrect for this ECM.
Different failure mode than the 7–9% idle pedals.
:cross_mark: :five: ATP / Navistar 2607117C91
Idle APP: 6.7%
Fault at: ~12%
Thanks in advance for any help you could provide. I can’t imagine junking this truck over a pedal.
Give use a picture. Then volt readings for both throttle tracks.
Idle and wot.
Most will be .5v-4v and 1v-2v. The key being one is always 1/2 of the other.
Like this?
699-5102
https://ebay.us/m/lmXSsj mine is this one. I don’t want to pay $1100.00 for a pedal that may last a week or a year. I’m looking for a replacement. I’ll check voltage closed/WOT on both tracks today and get back to you. I see the early GEMs use the same pedal drive sol p# 050g-e4634 just a different pedal arm and mounted upside down,. Polaris at one time had a limited run replacement PN:2010469, to me it looks like a Williams controls setup. If I could get this sensor # to the Williams sales engineer they could give me the proper sensor. If Im able to find a proper replacement I’ll post this on RV forums to help others as dealers and parts suppliers have been reluctant to really help me. I have tried many sensors based on the couple suppliers that have recommend something but none have fit the bill. I’ve cleaned the inside and as of now it works… At least for testing but I don’t trust it. Here’s a pic of my pedal…
This is the inside. I’m limited to 3 posts as a new member.
You can’t trust AI for everything.
I wouldn’t consider the GE controller as ā€œmodern dayā€. The T3/T5 controllers are 20 year old tech.
Throttle pedals from that era (gem car) use 2 inputs.
Track 1 is a switch. Open at pedal up. Closes at initial pedal press.
Track 2 is a variable resistor pad.
Yes, around 2012/13(?) Gem switched to a hall pedal design and a T5 controller, but still using the same pedal inputs.
@Matt018888 -
You are right. I wouldn’t pay $1100 for what should be a $80 part either.
That sure looks very close to what Gem cars were using for a pedal box. Even where the pedal arm rivets to the box.
What does your harness plug look like?
From picture;
NOT a hall type throttle, quite obviously it is a pot type. One track is 1 volt to 3.5 volt when supplied by 4.5v supply.
Track on left is fs1 idle sensor.
As Byron stated is looks identical to 2008 type Gem pedal. We both sell replacement pedals or pot boxes.
Ha ha.. you can’t trust AI for most things..Even in what I posted it changed its mind a few times. I continued the discussion with AI after I posted this and between us there were so many ideas and thoughts about what it might be. I finally said clear your memory and moved on.. ha ha..
I see so much on pedals.. I really never paid much attention since mine is a single pot.. simple is good for me.. But curiosity about this one for me is just that, a curiosity.
Interesting that when I first started doing research on these things I found my way over to RV forums looking for a replacement.
At that time they were also having troubles finding a solution.
Then the trail went cold.
I believe that Byron’s pedal is correct. It only needs harness adaptor to your plug, or your plug exchanged to one that fits new pedal.
Mine should plug in, but arm is wrong.
