GEL batteries dead after 15 months?
is the 7hp motor have the same rpm spec as the 5hp ?
Yes both are 4100
The 7 will pull more tire size or a better gear ratio.
[quote=OLD HOUSEBOATER;27578]Yes both are 4100
The 7 will pull more tire size or a [U]better[/U] gear ratio.[/quote]
Rodney,
“Better” means a higher number (12) or a lower (10) ratio?
jerry
10 , but you could even run the 8.x ratio.
just bought a 10.x yesterday . going to run it with my 5hp setup . i’m curious with the weight reduction of lithium and the low sag , if well still accelerate as hard .
Writing a how to but can’t post with pics till I post 5 times? This is just space filler, sorry.
The 7 will pull more tire size or a better gear ratio.[/quote]
My stock GEM eS with factory 7hp, no controller mods, tall tires and a 6:1 gear tops out at 40mph and still spins the tires.
Talk to me about 6 to 1 gears. I want to build a “Low Rider” And 6 to 1 gears would be an advantage. Where, who from, how much and how noisy?
[quote=OLD HOUSEBOATER;32163]Where, who from, how much and how noisy?
Rodney[/quote]
I bought the 6:1 gears from Marlon several years ago (and he seems to have disappeared). I think I paid about $350 for gears, bearings, seals. There’s a little whine at very low speed when cold, otherwise totally quiet.
Don
Interesting thread :wink:
