At some point in your life you will have issues with regards to recharging your G-Wiz and while you may automatically assume that the batteries are dead this is not always the case. The life of some G-Wiz batteries can be shortened if the vehicle is used for relatively short journeys and recharged on a regular basis. As with your traditional batteries this constant “top up” does have an impact upon value for money.
In some cases there may well be issues with regards to the internal recharging system and you may need the assistance of a professional. So, what is the problem with your G-Wiz batteries?
