Does anyone know the replacement turn signal flasher part # I want to change over to electronic as I am changing the entire lighting system over to LED. I found multiple threads relating to problems but cannot seem to narrow down the correct one for a 2002 E2 and it’s actual location. This GEM has been updated with the new converter if that matters.
Look under dash right side.
Perfect thank you, I will pull it apart this weekend.
