E-825 / e4 trunk backs compatible?
Hello - anyone know if a trunk back for a e825 would work on a 2008 e4?
I believe they are.
I remember there was some sort of clearance problem with the LinksBack golf bag carrier. That was more due to design changes down low with the spat or the bumper being on some cars and not others.
Since you are only up high with the two bottom frame mounts and the upper latch, I think they tried to keep thise standard.
Or at least it shouldn’t be too tough to fix.
Return back and post what you find out.
I would like to add that they both burn about the same.
I believe they’ll fit on the 2008 but you’ll need to add some pad spacers on the existing outer pads.
I have a 2002 e825 and a 2008 e4 which is a frankenGEM and the trunkback wobbles a bit because the body of the 2008 latch is a bit further back than the 2002 which causes the trunkback to lean about an 1.5" back and causing the side bumper pads to come up short of the body.
I can add a couple of pics tomorrow.
