On pre 2002 Gems the threads on the gearbox mounting bolts sometimes strip from over tightening. The fix is to drill the hole all the way thru the housing with a 17/64 drill and retap the hole full length. Then use longer bolts…
Related topics
Topic | Replies | Views | Activity | |
Removing the half-shaft from a GEM 2017 gearbox | 15 | 391 | June 18, 2022 | |
DIY GEM GEARBOX Refurb Procedure | 4 | 2661 | July 14, 2018 | |
2005 Gem Car leaks in the transaxle area | 18 | 4280 | April 25, 2019 | |
2016 GEM E4 making odd motor noise | 10 | 422 | May 1, 2024 | |
2000 E 825 transaxle | 12 | 2622 | February 22, 2014 |
