Am now able to handle DeltaQ repairs.
What is the retail cost and shipping policy?
Do they do simple repairs or only rebuild?
Can you specify a lithium profile as default?
On their site $325 is mentioned. Can that be right?
I have a DQCP72 that does not work with a programmer.
My first attempt to change profiles the tap method.
Nothing like the instructions.:noidea:
It seems to have 1 thru 6. Any idea what they might be?
I can set this to 1-9
These plus 9?
I might make trade for a non working DQCR and above.
[quote=Inwo;33537]What is the retail cost and shipping policy?
On their site $325 is mentioned. Can that be right?[/quote]
Reman to original configuration only. Do not add algorithms. Price is right. I charge $318. shipped back to the customer. I provide a convenience service. The customer doesn’t have to set up an account and it’s painless. My customers have been happy with my service.
Note everybody. Dave (The Genius) Saved me a ton of money by fixing my Chinese Charger for my boat. He can also do DQ’s. Talk to him.
I was thinking after I posted that it might be considered a hijack.:o
But then I thought. It will bring attention to your service.
I can’t refurbish to specs and offer a guarantee as I have no cooperation from factory.
Have you seen DQ72 with algs 1-9 in them?
Should be ok for Gems, right?
After I get thru testing, it will be for sale, as I can’t load lithium in it. (yet)
Ever wish that you could change the DQ profile without it installed in the car?
I’ve been doing it a lot.
No need to connect to a programmer with this.
Ok I’ll bite. How Much?
Just a tease.
One only. Proof of concept.
I can show you how to do it, but I have a few of these boxes with led and switch in them.
I’ll give you one next shipment, if you think it handy.
Made a few improvements.
The led now shows good connection to charger and good (programmer) battery.
Here’s how it works for me;
Connect clips to charger leads. Red to plus-Black to neg.
Plug in charger.
While charger is blinking profile code, press button for about 3-4 blinks.
Release for about 3-4 blinks.
Repeat a few times and let charger finish showing the profile code.
If fault light ever comes on, reboot charger, and try again.
To step to next profile, press for another 3 blinks and release.
It will now read next profile code.
When it blinks the profile code wanted, hold button in till blinking stops.
I found that most of the chargers had to be put in the program mode before they will input. While the charger is blinking out the installed code (11 seconds duration) I push the button for about 3/4 of a second. If it keeps blinking the current code it will then take the 3 plus second pulse to advance. If it red lights you have to start over. NOTE: this is in the factory procedure.
Rodney has a relationship with fsip for rebuilding Gem electronics.
I will tackle simple repairs for members as hobby.
No factory support-no guarantee. Less money.
That’s why I’m looking for Todd. Have the parts for his DeltaQ charger.
Copy, did you click on his profile avatar and were you able to initiate an message to him? If not, I can initiate a private message and include you in it.
