It is a 72V Delta-Q charger, updated to 96V with algo161. Troubleshooting with LitiumGods we finally figured out that I needed to disconnect the old temperature sensor that I had kept connected to the new battery. I removed the temperature sensor, connected the white wire from the Delta-Q directly to the negative terminal of the controller and it is now charging again! Appreciate everyone’s time and effort in helping me get through the lead-acid to LION transition!
Not quite how it works, but we getcha.
BTW,. you, Robin Leach, 30 years ago. Twins. I bet you don’t hear that all the time.
Interesting that it charged twice with temp sensor in place then decided it was not happy.
It sounds like it was looking at the lower threshold of 161 not being low enough to get out of bed for? The sensor still being in place must have been mudding up the white wire?
Going to chew on this one.
THIS is why I ask so many questions!
Thanks for coming back with the update.
