Some new members may not know about some of the things I make.
This is the neatest most reliable way to put balance leads on Volt modules.
Uses factory harness and bms enclosure. Almost forgot myself until I decided to do a trouble free install for myself.
Here’s what it looks like in the open.
Cell numbers are silk screened next to pads. Numbers are correct for Gen1 12s Volt.
For 6s use the top 6. 13-B+
$10 each
And done. About 1/2hr from digging out the boards and finding the oem Volt harness.
1-12s and 1-6s. Only the 12s shown connected.
Double holes in pads for qc terminals or parallel connections.
18s Volt module seen partially between seat and frame. Oem bms box on top.
Self contained 24s bt monitor will fit nicely on top with short leads. (RED)
