Hi !
I am trying to collect data concerning a device’s battery life (camera). I would want to calculate the energy my device consumed during a whole week without knowing exactly what current it would theorically draw. My idea was to use the difference between the initial and final battery voltage to extrapole the total energy; is it even possible to do that ?
Knowing that Ui = 8,28V and Uf=8,19V and that my Li-ion battery’s nominal capacity is 2.0 Ah, I would have donne
E=(8,28V2Ah)-(8,19V2Ah) = 0,18 Wh
but I am pretty sure this is not very accurate, considering that the formula E= C*Uavg uses an average voltage and I am now using specific voltage.
I have done the same exact week test with 8 AA alkaline battery (1,5V 2,5 Ah, 4x2 battery in parallel which would give a 6V 5Ah battery pack). Ui =6,27V and Uf=6,19V, which would give
E= (6,27V5Ah)-(6,19V5Ah)=0,4 Wh …
That’s more that 2x the Li-ion’s energy loss for the same use! That is the big why I’ve got doubts on my use of E=C*Uavg.
I estimate my discharge rate at approx 0,0001C (avrg 0,0002A and 2.0 Ah nominal capacity), and I my battery pack is almost fully charged (8,28V vs 7.4V nominal) so I would guess I can consider the discharge curve as linear at this point.
Do any of you have an idea of how I could know the loss of energy in my battery only using the battery spec and the initial and final voltage ?
