My parking brake buzzer doesn’t sound. It works in reverse. Ideas/reason?
hi
are this on Gem 2005-up ?
did brake lamp go on and off then relase park brake ?
No 1999 4 seater.
I THINK the earlier GEMs had only a two wire circuit for the ebrake. JAT but any chance ebrake switch has [U]both[/U] NO (normally open) and NC (normally closed) contacts w/ center neutral (i.e. 3 lugs) AND you got the wiring “switched” to the wrong lug? Maybe if you replaced the switch or had the wiring off for some reason?
It fixed it self. Will wonders never cease.
