Battery not staying charged
My battery charges to 100% but if I leave it charged in for two weeks it drains down to zero. Is this nori.
Really in two weeks? Either bad batteries or a large parasitic drain.
Too vague- Need more info.
What is this car?
What is the battery?
What is the charger?
What is the age on the battery?
Are you switching the Main Battery Disc to OFF?
The car is a 2025 e4 with a lithium battery. I am not switching to long term storage or switching the battery DISC to off.
Thats about right if you don’t flip the switch off. I have a massive lithium battery and it will go a little longer before it drains.Just flip the switch in front and it wont do that.
But if I leave it plugged in shouldn’t it remain charged. The car is at a second home and I plug it in when I leave and may not return for three months.
John
Someone replied to your post.
| LithiumGods
October 25 |
I believe the 2024 and newer GEMs no longer have the 12 volt aux battery under the dash. Instead, the dc/dc converter is on all the time putting a constant draw on the main battery. That’s why they put the convenient cutoff switch in case one doesn’t expect to use the car for 10 days or more.
I also don’t think the charger will start charging again after a full charge unless the car is unplugged and plugged in again. A timer on the receptacle would cure that but I would never do that to an unattended car.
I don’t have my owners manual handy but it seems it had specific instructions on storage for 10 days or more.
Turning off the power switch should take care of your issue though.
Thank you. What is the issue with a timer on the receptacle if the car is unattended. That seems like a good solution to my problem.
Not sure about your battery but my LifePo4 batteries like to be well below 100% if stored for an extended period. So the timer seems to be practical for lead batteries just not my lithiums. I think turning off the power switch after charging if storing for an extended period is your best option and likely the one recommended by GEM for 2024 and newer.
I think the problem here is that the OP → @jbrennan is still using lead acid thinking.
Previously, one needed to keep a LA cart plugged in and “floating a charge” especially when leaving the cart for long periods of time.
Lithium batteries do not need a float cycle. The general practice is to charge the batteries whenever you feel like it. Sometimes this practice might leave you ready to venture out on a big day with only half charge on your cart. This is more about planning ahead fault and needs to be adjusted in your practice so you need to think ahead. If you are using the car heavily, charge your car up at the end of the day. One never knows what you will be into tomorrow.
The only exception is for long term storage. Most manufacturers suggest not storing your pack at high SOC (100%) if you are not planning to use it for a while. Figure 60%.
As noted by others - When you are NOT using your car, it is best to fully power down the car systems via Main Disconnect Switch (not the key switch) otherwise the ancillary drains will still be pulling power and drain your pack. Mainly this is due to the DC-DC converter keeping the car in ready state even tho the key is off.
Sure, you could leave the car plugged in as long as you are sure the charger will cycle (every week) to top off what the DC Converter is burning off from your slowly draining batteries. Some charger profiles will do this, but not all. The same advice applies to running a tiler on the input.
The extended problem on this scenario is all of the things that could go wrong. The charger could fault, the power feeding the charger could fail or, the GfCI feeding your charger could trip. If the power goes out, the heavy spikes on the input side when it comes back up really don’t play well with things still plugged in.
If you are away from your car for a month/two, power down via MainBattDiscSw->OFF. As long as there are no random wires still connected(like radio memory wires?), your battery will be fine. To be safer, log into BMS and shut off the outpur FETs(which also provides a layer of security). With the BMS still active, it’s very easy/cool to walk by and log in via phone app just to occasionally check on it. BMS being active still takes a bit of power. Expect a little drop.
If you are winter storing (4-8mos) then power down via BMS full shut down(put it to sleep). I have come back to batteries that have been sitting for years that still test fine with very little drop.
