But wait, the title says Two Gems:
After a….long…2021 for our family, which included adding a new member to the team, our little E825 wasn’t big enough for our party of 5 now. Insert: an 07 E4.
After a fairly length search, we found this one for a decent enough price with less than 6mo old batteries, and immediately got to work transplanting as much from the E2, and preparing it to sell. This one too needed a little TLC, but less costly compared to our first one: brake pads and bleed, headlights, CV boot repair and motor service (more on that later).
Now that the main maintenance items were addressed, it’s time to move on to the heart transplant. Similar mounting as before, but now under the rear seat AND with a BMS!
I figured out the BMS leads are the same layout as an IDC connector, or a shorter version of an old IDE connector for computer peripherals. So I found an IDC to terminal board, thinking it would make my life easier hooking up the BMS. While it “sorta” was, the limited real estate between the car frame and the battery orientation caused me to have to do a lot of double work. I would probably use them again but definitely re-think the design.
It was now time for the rear seat/cargo bed. I used the cargo bed so much on our old one, I couldn’t imagine not having one on our new one; plus the extra seating capacity is nice.
Problem is, I can’t weld, and didn’t have the help of my brother/father-in-law to weld a frame for me. So I found one of the most universal/modular rear golf cart seats I could find (and one of the least expensive too luckily enough), and got to work figuring out the safest way to bolt it on.
DISCLAIMER I’m not an engineer, nor have I thoroughly tested the load capacity or resilience yet, and no one has ridden back there up to this point. I TAKE NO RESPONSIBILITY IF YOU DECIDE TO TRY THIS ON YOUR OWN.
I loosely assembled the seat and took some measurements, then cut some 1 ½” square steel tube to length.
Test fit just about perfect, with the foot support brackets about 1cm away from the bumper. Drilled some holes to line up with the perforated steel cube, and tightened it down.
Had to notch part of the seat bracket to slide the bolt attaching the square tube to the frame, to allow a flush fit.
I reinforced the front (rear?) of my mount with some extra pieces of square tube, so that any weight in the far rear is supported. I’m most likely going to change this out to a flat ⅝” thick steel plate on both sides of the frame.
I then attached the top of the arm rest rail of the seat directly to the frame behind the seat, using a spare bracket that came in the seat package. I’ve also changed this to a grade 8 bolt since this picture. This is all I had that would fit at the time.
And here’s the finished (for now) product. Still need to add an extra support bar for the step, but overall I’m happy with how it turned out. I’ve bounced on the back of this thing with a few heavy rubbermaid tubs on the back without a creak or groan from anywhere. Still going to do a lot of testing before I’ll let anyone ride back there.
And just when I thought we were ready to take this thing out on the town, this happened:
But thanks to @Inwo , I got a sweet practically (better than) new motor, and the E4 is one step closer to primetime!
Currently troubleshooting and learning the BMS, and still have a few bits to clean up on it before it’s next big transformation: Voodoo Blue!
Just want to shout out to everyone on this forum, with special thanks to @LithiumGods for numerous calls, messages and emails helping me with my lithium setup, and doing his best to keep me from wearing that “dummy” hat. One day I hope to help contribute at least a fraction of what you guys have contributed!
