SOC outline will usually flash when the batteries are dead.
The brake light can also be turned on by the brake master cylinder brake fluid level switch. Located under drivers dash cup holder.
If it has a power point on the dash than it will have two dc/dc converters. One on either side of the frame rail, exactly opposite from each other. You will need to reach your hand around to feel the back one.
I did check the fluid level as well as turning the float switch upside down. I do not have the power point so I only have the one converter I will check the fluid level float switch operation with a meter this afternoon.
can someone show me where in the wiring diagram it shows the parking brake circuit? I have the parking brake switch working according to the multimeter, but the cluster is not seeing it.
Is there a true wiring diagram somewhere? I have looked through the power and ground distribution pages and either missed the fluid level and parking brake switches, which is possible scanning them on my phone. I see the brake lights on the 12v side and I would think that those switches would be on that side too?
I have the service manuals but I not found anything for any of the control wiring or pinouts on the cluster.
Any idea why the battery outline is blinking on my cluster? It’s trying to tell me something, maybe just too high of voltage. I know the battery is not dead. Lithium battery with 90 Volts and a full charge.
There it is, darn it, I looked yesterday. It is on the 12V side so maybe when my new converter shows up That problem will be fixed as far as the symbol on the cluster.
I should mention that the cluster is showing 5 bars of charge with the outline blinking fast. If I am reading the above sheet correctly it will only blink fast with zero bars and slow with 1 bar.
Absolutely. Connect to monitor mode and it will show you what’s missing.
You need B+ to controller when contactor pulls in.
Also on p1 an p2 with key.
12v from p15 on
P3 when throttle pressed.
P4 5 or 6 one only for direction
P7 has rising voltage 0-5v with throttle.
P9 don’t know which direction 2nd pot goes.
P21 from motor switch.
