@Erniea15 It’s still under warranty. My plan is to have it swapped as long as it is the source issue. From the above, I do not think anyone is alluding it is not the charger itself that is the cause, unless I’m misunderstanding.
@AssyRequired 3 plugs coming out: female 3 prong AC input, male 2 prong DC output, and a purple tipped data cable on the output side of the charger. I think that no lights is a good sign, in that we’ve likely located the source issue and can move on to warranty replacement. Also, I’m going back within the next month. Sooner than a month if more diagnostics need to be completed.
@djgabriel2004 Interesting. My one complaint with the service manual I bought is that it doesn’t really go into diagnostics at all besides using the digital wrench diagnostics reader, which I would love to get my hands on, but am not a dealer so that’s probably not happening. So, it’s great to get this kind of feedback.
Does the 120v input only check indicate anything if the lights are still off? Just tried this procedure the way @Inwo described it above after realizing you were describing the same diagnostic technique. See pictures below for the results of the plugged in charger and ODO display:
As far as DC voltage not being seen unless it’s attached to the battery, are you saying the charger needs to detect a connection on the output side before opening an output relay, or did you mean amperage? It would seem weird to me that the charger wouldn’t just send power based on the BMC send signals, unless it’s a safety mechanism. Voltage should always be present if the BMC is saying send juice, unless there is some sort of open detection method on the charger output side. To read amperage, you would need to complete the output circuit with your multimeter probes, which sounds more like what you’re describing. Again, I don’t understand how the charger is designed, so just trying to learn more.
The vast majority of the service manuals A code descriptions / resolutions involving the charger ends with “If the problem persists, the charger has likely failed, Please contact Tech Service prior to replacement”. This likely happens quite a lot. Basically, unless we can point to it being something not contained within the charger itself, it’s getting sent back under warranty. If we’re talking about it being something else, please let me know.
Thanks to everyone for the feedback so far! Hopefully this helps someone down the line with a similar issue.
