I have an 09 -4 seater and I’m running 17" Mini rims on mine and they are 4X100. The offset is not correct so I have ordered 1.25" 4X4 to 4X100 spacers. The 4X100 will bolt up fine but since I needed a large spacer it was just as easy to order the 4X4 to 4x100…
The correct offset will effect if the rear spat will sit correct centered over the tires but it will need to be raised slightly. In my case, yours may be different.
I love the ride, love the tracking and the height is so much better. I have had 1 overheating problem that I attributed to the tires and loose cables. Not sure if one or the other caused the issue. Good luck
